Sole F63 Won't slow Down
Hello,
I recently bought a 2nd hand Sole F63. The treadmill will speed up just fine but it will not slow down. When you hit stop to pause the workout, it does not stop. You have to hold down the stop button to get the motor to turn off or pull the emergency stop. I have already replaced the speed sensor and ran the calibration and it still doesn't slow down. Any suggestions?
  • could be a issue with stop button in console
  • If the treadmill doesn't go over 2.0mph, the stop button works. It pauses the treadmill and will stop the workout. The treadmill also maintains the fastest speed that you put it on. If you set it to 4.0, then want to go back down to 3.0, it will not move from 4.0.
