Horizon premier t901 treadmill
I just purchase a Horizon premier t901 treadmill. The speeds are way off. 5.0 on that is like 3.0 on my old if not slower.
This treadmill was used but only had about 50 hours on it with less then 300 miles, There is a code you enter to see the accumulation. I have search to find all the codes for this treadmill and what they will do and I can not find any.
One code I found was EN91:Hardware Test but when I push enter it does not do anything.
  • You can try this.
    ENTER ENGINEERING MENU
    NAVIGATE THROUGH MENU
    SELECT MODES
    EN90
    EN91
    EN92
    EN93
    EN94
    Press and hold the
    Incline Up/Plus and Speed Down/Minus
    for 3-5 seconds. Incline Up/Plus
    Incline Down/Minus
    Speed Up/Plus
    Speed Down/Minus
    Arrow Navigation Keys Select
    Change Display
    Enter Display Test Hardware Test Auto Calibrate Switch Function:
    Press Enter to Change Models
    Press Start to Change
    MPH (0) / KPH (1)
    Press Incline or Speed
    Up/Plus or Down/Minus
    to Turn Demo Mode on/off Information:
    Displays Total Time and Distance
