Nordictrack C2000
Hi, I have a Nordictrack C2000 model NTL 1084.1. When I start walking the treadmill will slow down, you can hear the motor slow also. This stops when I reach 1.8 and beyond. I centered and tightened the walking belt. I have checked the drive belt and it looks new and is very tight. There are pieces of the belt on the bottom, I am assuming from the belt being new. It does not look frayed or worn in any spot.
Now to my questions. Does anyone know the drive belt number and how tight the belt should be?
What could be causing the slow down?
https://www.treadmilldoctor.com/nordictrack-c-2000-treadmill-ntl10841-motor-belt-220769
Once you've added items to your Cart, and you are ready to Check out you can put this Discount Code ( 8264 ) in the Discount Box on the Check Page where you put in your Billing and Shipping information at. You will see your Discount Amount Applied on the right side of Page.
LUBE DECK
