Treadmill turns on, incline works, but belt won't move.
                    Hi, I got an issue with my treadmill.  It turns on.. I can make the incline go up and down.. but when I press start the belt won't move.  I've tested the motor with an external power supply to see if that was the issue  by hooking it up to a cordless drill's battery and the belt moved.. so the motor must be fine..
Anyone know what else would be the problem please? Or what and how to test next please?
Thanks.
Thanks.
have you checked your wires for voltage? tested the motor?
did anyone test the red wire & the black wires?
