Nordictrack C2200 slow (constant 1mph with no weight)
Hi,
This is my first post. I have a Nordictrack C2200 that is slow. No matter the speed setting the motor turns at that same rate (there is no visual or auditory clues that the unit is increasing speed). when I step on the platform and set a speed the belt does not turn (but I do not hear the motor turning).
Do you have any ideas?
thanks
  • Sounds like maybe you have a issue with drive belt or pulley on front roller.
  • MY RUNNING BELT STOPS WHEN I STEP ON IT
    B) If yes then it could be a weak Drive Motor or bad Motor Controller.
    B) If just the pulley on the front roller continues to spin, then you will need to replace the entire front roller.
