Nordictrack c2000
I bought this used. Worked perfect for demonstration. Get it home. Ran for about 15 seconds and dead. Acts like it has no power. I took cover off and have the solid red light. Performed reset as instructed in manual. Im at a loss of what to do next.
  • Good morning!
    the solid red light is good - that means that part is getting the correct voltage...
    here are a few things you can check when you do not have power:
    please check to make sure all wires are securely plugged in inside
    make sure there is no crimping in the wires
    If you do not have the voltage then the motor controller is bad ( which we know you are getting voltage as the red light is on)
    you might just need to replace the wires!
