Motor Drive Fan for Keys Fitness MS2200.2C/Milestone 2200
There are two motor fans on my MS2200 treadmill drive motor. The one on the pulley side is intact. However the one on the opposite side is broken. It looks a lot like https://www.treadmilldoctor.com/plastic-cooling-fan58 or https://www.treadmilldoctor.com/plastic-cooling-fan12 as it has the rotary encoder fingers coming from the hub like the two models. The fan on mine is held onto the motor shaft with what reminds me of a spring collar used to hold barbell weights in place. Will the appropriate diameter of the two models above work for me? Of course I will measure the motor shaft diameter before ordering but it looked like it was around 1/2 to 5/8".
Thank you,
David
  • Yes it will. Once you've added items to your Cart, and you are ready to Check out and you put all your shipping info in. Use this code 1982 at checkout for a 5% discount on your order.
