Testing the motor
Hi everyone.
I had a problem with an old Nordic Track treadmill back in November. I got in touch with someone who could repair it.
I took out the control board and sent it away. The gentleman who received it confirmed that the board was broken and needed repairing BUT the problem with the board could have been originated in the motor itself. For such an important item I contacted the manufacturer and they gave me very few options. Either send a technician to look at it as a very high cost or to buy a new motor. Since we are living in difficult times I would like to keep costs to a minimum and try to save the existing motor. I did a google search and found quite a bit of information but basically, if the motor is good it should work when applied a small voltage. I grabbed a battery charger and submitted a 12 v current to the motor and it immediately and happily started running. Further to that, I measured the internal resistance of the motor which gave me a legitimate reading, and also checked the resistance between one of the terminals of the motor and its chassis. The result was OL as expected.
So the question is: am I ok to assume that the motor is good?
One last detail I would like to add was that the battery charger that I used to feed 12 volts to the motor has an amp meter. When I switch it on the motor starts running and the meter shows a spike of about 15 Amps or thereabouts for a split second. The value then drops to 2- 3 Amps when the motor is rolling. Am I correct in assuming that the spike is normal and nothing to be worried about?
Many thanks for your help
M
M
Give us a call at 888-362-1105 if you would like some help with finding a part!
Hope to talk to you soon!
