EPIC EL1200 left housing/bearing have seperated
I have a EPIC EL1200 Commercial PRO. The left rear bearing has seperated from the housing causing the housing to unscrew from the center tower. I need to remove the crank flange from the shaft so I can then remove the bearing/housing to reassemble them. Then I can thread this back into the threaded hole in the center tower. Problem:I can’t get the crank flange off of the axle! I don’t want to damage anything else by forcing it. Help!!
You have to unbolt the 4 bolts that go from the backside through the flywheel into the crank arm.
