Need Belt Replacement: Bavatus T4 Not Listed
edited July 9 in General Discussion
I have a 20" by 118.5" treadmill belt that needs to be replaced....is there one of this size?
I see treadmill belt size 20 x 118 or 20 x 119....should I get .5" bigger or smaller?
  • I would go with a 20 x 119 and also here is a code to save yourself 10%.Once you've added items to your Cart, and you are ready to Check out you can put this Discount Code ( 8264 ) in the Discount Box on the Check Page where you put in your Billing and Shipping information at. You will see your Discount Amount Applied which is 10% on the right side of Page.
  • Thanks but I'm concern it could be loose.
  • Then you can go 20 x 118 but it may be very snug when putting it on. here is a code to save yourself 10%.Once you've added items to your Cart, and you are ready to Check out you can put this Discount Code ( 8264 ) in the Discount Box on the Check Page where you put in your Billing and Shipping information at. You will see your Discount Amount Applied which is 10% on the right side of Page.
