NordicTrack C2150 not powering on
When I turn treadmill on using the switch the console fan comes on for a split second and the display is blank. Magnet thing is in place. Firgured it was the control board so I replaced that and still same problem. Cable from the board to console looks ok. What else could it be? The red light on the board stays on when I turn on the unit so its getting power. Treadmill worked fine, didnt use for about 4 months and now its like this. Thanks for the help.
  • Could be a console issue, If you have a voltmeter you can check to see if you are getting 8 to 12vdc on the red wire & the black wire. If you are then the console is bad and if you arent't then mcb is bad.
