Treadmill belt replacement - Proform 390
I recently replaced the belt and motor on my Proform 390 and need to confirm the belt is on correctly. The belt does not sit flush with the deck, it's essentially suspended a couple centimeters above the deck and it's noticeable when you take a step. The rollers were tightened enough to prevent the belt from slipping but no more.
Can anyone confirm if this is correct? Should the belt be running directly on top of the deck?
